Export to Illustrator
10280.2 In reply to 10280.1
Hi Cary, well there are 2 different modes for the illustrator export, you can either export curves that you have created in MoI, or you can export solids in which case a hidden line drawing will be generated.
For the curve export, if your curves in MoI are closed then they will be closed in the Illustrator file as well. For the hidden line generation it does not currently generate closed curves, sorry. That's because there are many situations with hidden line drawings where the generated curves do not form a single closed outline.
