Can you do this
10266.3 In reply to 10266.1
Hi Booleano, I don't know of a script for doing that. Probably the easiest way is to use Edit > Separate on the curve to break it apart. Then select and delete all arc curves (select all and then use Details... to select arcs). Then select a pair of lines at a time and run Edit > Extend. Right click to do "Mutual extend". Select another pair and right click to repeat the extend command, etc...
That goes pretty quickly, here's what it looks like:
