problems with offset
10263.10 In reply to 10263.9
Hi Art, can you please post the .3dm model file with the object you 're having problems with?
One thing that can make things difficult for chamfer or fillet is having surfaces that are not smooth to each other but are not too far off from being smooth.
The reason being that part of the fillet/chamfer process involves intersecting offset surfaces and 2 surfaces that meet at a shallow angle have more of a "zone of overlapping" rather than a crisply defined intersection.
So I'd probably try to make some of the pieces to be longer single smooth surfaces rather than fragmented into many faces with shallow angles to each other.
There is a kind of similar recent discussion thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10210.1
Anyway, if you can post your .3dm model file I can take a look and try to give some feedback. It is very helpful to post the .3dm model file along with your question instead of only screenshots.
