Loop in complex objects
10262.7 In reply to 10262.6
<< Export curve
I believe you must export object then extract curves in Moi! ;)
It's the limitation of the OBJ format
but you have the export DXF ! ;)
Seems not working inside Moi :(
So I use the free astonished PCONPlanner https://pcon-planner.com
Import inside the DXF from Rocket 3F then export inside Moi DXF that works! :)
EDITED: 1 Apr 2021 by PILOU
