Realtime mirror and blocks/instances question
10261.8 In reply to 10261.7
VClone will make only clone an object on some vectors!
I believe that you must make the last solution! (against the VCLone )
That will be more easy!
BoundingBoxCenter of all 50 objects selected (There is a little problem that give only one point! :)
(i must found otherthing) you can yet click one object call the function, click an empty space screen, click one object, right click, click an empty space screen, etc but...
Then CopyToPoints of your new object
(maybe you must get down points depending of the gravity center of the StartBoundingCenter )
EDITED: 1 Apr 2021 by PILOU
