Seams
10245.6 In reply to 10245.5
Hi Art,
> Guess I was referring to the ability to merge two edgecurves into one like you can on normal curves?
> Is nt not possible because of the nurb line running down the center of the model?
Yes that's correct - 2 edges can only be merged together into a single longer edge if they are the only 2 edges touching each other. If there are additional edges connected then it can't merge them.
> But I also wasn't sure if something geometrically was screwy in the nurbs
> themselves. Thanks for the help, sorry for the confusion.
No nothing is inherently wrong with that. It can be a good idea to have larger faces when possible instead of multiple fragments but it does not ruin the model to have some of those.
I do want to update the face merging for boolean union so it would merge the cases you showed.
> Discovered can simply assign a style to edges I find unsightly and simply hide them.
You can also select them and use Edit > Hide without assigning a style.
