Obj object from nurbs
10244.5 In reply to 10244.4
Hi Tony,
> So you advise me to generate a chamfer instead of the radius?
Yes, if it's in a small area that will not be zoomed into closely in a render.
> I tried to use the option to generate fewer polygons but in curved surfaces it creates this problem that I attach
Your value is too large, reduce it gradually and see what results you get. For example try a value of 4, then 2, then 1, then 0.1, etc...
The result you want is that only very small sized fillet pieces will get the coarser mesh.
