I can't finish this
10233.3 In reply to 10233.1
Hi Booleano, what about if instead of making the neck bottom a straight piece, if you instead made it a sweep that curved downwards at the end like this:
Then if it is trimmed by a side profile you'd get this kind of shape:
And also if the sides were extended up like this:
Then it could fill more space up and get trimmed down:
So you'd be getting this kind of larger trimmed surface instead of a patchwork of separate pieces:
Then the tricky part becomes adjusting the shape of the sweep so that it comes close to the end profile that you want since the end profile is formed by a trim rather than drawn in directly.
Does that seem like it's better or not?
