Hide unhide
10220.5 In reply to 10220.1
Hi Zooen,
> It's me again . Is there a srcript or a manipulation to recall only the last hidden objects.
You can do that with Undo if it's the first thing you do after the hide.
If you want to return to a specific hide/show state after doing some work, you can do that using the "Isolate" function. That's triggered by doing a right click on the Edit > Hide button instead of a left click.
Isolate will hide everything else other than what is selected, leaving just the selected objects visible. It will also retain a memory of each object's hide/show state before the Isolate was done and restore it when trigger it a second time.
If you repeatedly need to hide/show the same objects, then it's time to assign them a name or a style and use the scene browser.
