How to use Flow?
10215.9 In reply to 10215.8
Hi Jack,
> for #1, your solution is good, but it is time consuming, we need do each curve individually.
You don't need to do each curve individually, in sweep you can select a bunch of curves as the rails in one use of the Sweep command.
Here's an example:
