Hi Jack, for your #1, one way you could avoid the deformation would be to flow curves instead of fully constructed tubes, then sweep a circle on the deformed curves.
For your #2 that's making a strange result because of this:
quote:
In projective mode, rays are fired out from the base plane along the base plane's surface normals and intersected with the target object. The target object should be large enough so that these rays actually hit it and do not just fire out into empty space.
