Hi Jack, there's some pretty detailed instructions in the help file here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
quote:
For projective mode the target object can be made up of multiple joined surfaces if they are all smooth to one another.
In projective mode, rays are fired out from the base plane along the base plane's surface normals and intersected with the target object. The target object should be large enough so that these rays actually hit it and do not just fire out into empty space.
Do you have an image or sketch of the result you're trying to get?
