finding parting lines for mold making in MoI
10212.4 In reply to 10212.2
> Seems any curves (or surface, or volumes) can make that ... just boolean diff...on any volumes...
> with keeping or not volumes depending of what is wanted...
> here curves
No that's not the same thing. It's not only just cutting a block into 2 pieces anywhere, you need the cut line on the surface to be at the furthest outline from a "pull direction", which is what the Construct > Curve > Silhouette command will calculate.
Once the object is cut along that silhouette then you can construct some surfaces going away from it to divide the block.
