Fillet issue
10210.9 In reply to 10210.6
Hi Billa,
> ok that makes sense, but what about this side? I tried making it one smooth plane, by deleting the faces and
> lofting, which didn't work and i tried using network, which didn't work either. So how would I get away with
> one smooth plane, on angles like this?
You'd need something like a sweep that has long smooth rails running the whole length of the piece. It would need to be extended a bit so that it pushed through the surrounding surfaces and so could have its excess outer zone trimmed away.
But that middle zone changes shape quite a bit in a small area and that makes it harder.
What is the end result that you're looking for, is it everything being filleted or do you want some edges to be sharp in the end?
