Hi Mewmew, so the file you're looking for is the "moi.ini" file, it's a little confusing in that first screenshot where it looks like it's just named "moi" because Windows (and Mac too) hides file extensions by default so you're not seeing the ".ini" part at the end.
So to locate the moi.ini file when you are inside MoI push the "Options" button in the lower right area of the main window, and inside Options > General push the "Edit .ini file" button.
That will open up the moi.ini file in TextEdit.app .
Then you can replace the entire text contents of that moi.ini file with the SHORTCUTS_MOI_default.txt contents, note that this will lose any settings that you have changed. It is possible to just splice in the keyboard shortcuts without disturbing other settings, let me know if you want to do that and I'll give you some further instructions for that.
