Dimension in Microns
10194.2 In reply to 10194.1
Hi Mindset,
You could set your options>general>units unit system to "no unit system".
Select a dimension which has been added to the model. Click Details in upper right corner. In the Object properties popup, the Text: box will have <>
which (I think) is a place holder for the dimension number.
Replace <> with <> micron. Or <> mu, or <> u (with front tail).
This will show the dimension as, for example, "1,234.56 micron" etc.
(Or "1.234,56 micron" , (Euro style). This only changes the displayed dimensions.
A dimension preset could probably be done, to default to <> micron, but I have never done this.
I believe that a micron is a metric dimension.
Output to PDF would be ???
Output to some other format???
Some care should be taken, so no one misinterprets dimensions.
Someone else probably has better suggestions.
EDITED: 28 Feb 2021 by BEMFARMER
