Dimension in Microns
10194.11 In reply to 10194.8
Hi MindSet, when you're done and ready to make a Microns version output, do a Ctrl+A to select all objects and run Transform > Scale, at the first prompt for origin point type 0 and push enter, and at the second prompt for scale factor type in 25400 and push enter, does that generate the dimensions that you need?
You can insert the Microns units label on all dimensions using the process Brian describes above by going to "Details..." and modifying the Text value to place your label after the <> value.
