How to create this contour form ?
10161.7 In reply to 10161.6
To build on what Brian and Michael posted -
You just need to pick the green, red, orange & blue curves and perform Network.
If you want to turn this into a Solid, select 3 curves that make a plane and perform Planar. The example below shows making the bottom planar. Repeat Planar two more times for the sides.
Finally, select all the surfaces and Join. The result is a Solid.
EDITED: 13 Feb 2021 by EDDYF
