How to keep individual cooplanar faces in a Loft (straight/exact)?
10160.3 In reply to 10160.1
Hi Ed, for now a workaround instead of doing a pair at a time is to select the result of the loft, run Edit > Trim, select all the loft profiles as cutting objects and set the "Keep all joined" option in Trim. That should dice up the coplanar areas.
