Node Help
10159.6 In reply to 10159.1
Barry,
Brian has already provided you with a universal solution for all point cases.
However when working in 2D on the ground plane, it is not necessary to concern yourself with point rotational data,
hence the Rx, Ry, & Rz outputs need not be connected to ptExt node "angle" inputs, indeed it would suffice to use regular points/point node.
Also Basic/Extract nodes could be used instead of splitPts node, since the only required data outputs are x & y data.
See below
Hope this helps
EDITED: 12 Feb 2021 by JFH
