PDF export
10153.6 In reply to 10153.5
Hi Carlos,
> I think i found an issue about the Moi's PDF file export.
> The layers (like styles) are present when opened in Adobe Acrobat Reader, but not present (the same file, in my tests)
> in Adobe Illustrator (CS6 to CC2021), which i use to edit the file, if need.
That's an issue with Adobe Illustrator's PDF file import - it does not support reading layers out of PDF files. It may appear to do so since it will read them from PDFs that it generates itself if "Preserve Illustrator Editing Capabilities" is turned on in its PDF export options. But that works by embedding some proprietary extra data in the PDF file. Adobe has not documented the structure of this data and so other programs are not able to generate it.
But you can use .ai format for transfer from MoI into Adobe Illustrator which will support reading layers and has all the same content in it as PDF.
