To much Icons in the Commandbar
10135.3 In reply to 10135.1
Hi wsiew, for the CustomUI v2.0 beta, the one that works with MoI v4, each button is generated by a separate .js file in your MoI appdata startup folder.
So to remove some buttons you would remove some of the .js files.
On Mac the MoI appdata dir is in ~/Library/Application Support/Moi . By default the OS hides the Library folder, so to go there use the "Go to folder" menu item on the "Go" menu in finder and put in ~/Library/Application Support/Moi .
Then inside there go into the startup folder, that's where there will be a .js file for each button you're seeing. Move the ones you don't want somewhere else, they can go into a sub-folder underneath startup, only the ones directly inside the startup folder will be processed.
> The button for this is on the right end i can't see.
There is a scroll bar on the bottom you can use to scroll over to it.
You can set up a shortcut key for opening the Options dialog by putting this in as the command part of a shortcut key:
script: /* Open Options dialog */ moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' );
