v1 beta - axis snap + IGES (old thread)
1013.2 In reply to 1013.1
Are you sure of the fonction Snap axis?
Seems nothing special appears different than previus??
A syntax error? a good dll? ...
And this function is enable / disable when you press the shortcut key for a second time?
Must some snap options must be enable also?
I have enable all and disable all snap: same result !
Can you put an image of what this "snap" suppose to do?
Or I don't remember how it was in the past :)
is that? the helpers is drawing without clic drag unrelease? So just clic & move?
Ps and other Lines Helpers are not keep too ?
EDIT But curiously that works not the first time I launch the prog but When I relaunch it, that works fine :)
And seems there is perpetual! :) no need to call the shortcut ???
EDITED: 11 Oct 2007 by PILOU
