Request for help measure and polygon
10124.12 In reply to 10124.11
Hi Burr, yes that's correct it's always been that way. It's a kind of special case because the polygon command has an input field for number of sides and that's where keyboard focus will go if you start typing.
It's on my list to investigate some kind of Tab key combination that will put keyboard focus into the XYZ control always maybe something like Shift+Tab, or Ctrl+Tab. Or maybe the polygon command should have a radius value field so you don't need to use distance constraint.
