You wrote:
"...the second is redraw with one or more curves perpendicular between them for make a surface of what you want exactly
and past it to the ring tube!...
Can be of course quasi all forms you want...
Like here with a Flow function..."
After pasting, you do a cut and delete the cuttet part? (I tried to modify the cutted segment, but I got no points to move...)
And if cutted out - I tried to make a rotating profile. But like you can see the surface from this higher part to the ring is not smooth.
rgds. Mala
