Filleting a Böbbel
10113.55 In reply to 10113.54
That's great Mala, you've got it! :)
This one needed some extra careful precision construction to get the fillet working ok.
It is helpful in construction to figure out how to do it with the smallest number of profile curves. This not only helps with accuracy by using the same cutting objects for different pieces, it also helps make the construction go quickly so if you need to make an adjustment you just delete it, adjust the profile curves and rebuild it.
If you need to use some 3D curves in the construction, try not to make them separately but instead use edges that are the result of cutting by 2D profile curves.
