Boolean Subtractions
10111.5 In reply to 10111.3
Hi denbutler,
> Try this experiment:
> 1) draw a solid box on one layer
Ok this is what I drew:
> 2) draw a sphere intersecting the box on a second layer
I made this:
> 3) boolean difference the two - not keeping objects
Ok, that makes this result, it's a solid with some of it's faces assigned to different styles:
> 4) you should now have a subtracted solid, but appear to have two polysurfaces, one on each layer
Incorrect, I've got a single solid which has some of its faces on one style and some of its faces assigned to a different style.
For example if you click on it you should see it select as one object because it is one object:
> 5) save file and reopen
> 6) now you have the subtracted solid, on its original layer
I saved to a 3DM file and reopened and got this:
Did you save and reload to a different file format than 3DM ?
So it sounds like you don't like the feature in MoI where it allows different faces of a single solid to belong
to different styles. If you like you can disable the generation of multi-style solids like that by a
setting in moi.ini:
[Styles]
DisableSubObjectStyles=y
