Problem with y-joint pipes
10104.1
Hi there,
I am pretty sure you will laugh (or at least smile) about my question, but I struggle with this (for me not so easy) task to construct an y-joint with 3 pipes. I got it ok'ish, but I think there are still some problems. I tried it in different ways, but ended always with problems fitting all three parts together. I started with a circle, extruded it and copied it 3 times. I rotated the upper ones 15 degrees upwards from the horizental line, did a boolean merge and boolean union these two parts together. I did the same boolean operation with the lower pipe. All looks ok and the last thing was boolean all parts together and a shell operation.
Is there a better, or right way to do it?
Size: 184.7 KB, Downloaded: 45 times, Dimensions: 833x539px
