Finding center curve of a tube like solid
10098.33 In reply to 10098.26
@HansChristian
Sorry, I think I have made more steps and forget explaining.
It's a reverse thinking from result to conditions.
The first question was to do a "middle curve" and my solution is based on doing an Iso curve from a surface.
This surface is done with initial conditions given, the "squared tubular cutting".
To do an iso curve, I need a surface and only one surface, not a joined surface.
To have an only one surface constuction, lofting need to have "soft curves" (no angular point on the curves).
So I use a "reconstruct curve" with many points to have these two soft curves.
The middle curve is not an ofset, it's an iso (V iso I think).
Iso permit to have the center curve of the surface even if the distance between the 2 initial curves is not regular.
Next I use the iso curve to do the sweeping.
But I think, the initial question was to do a circular border.
The easier way for this (I think it, but perhaps I'm wrong) was the first method explained, with a "Curve/Project" to have a curve and to sweep a circle with this projected curve.
This method is in my file too.
I used "reconstructcurve", but it's optional here.
