Modelling a Böbbel
10096.69 In reply to 10096.66
Hi Mala, maybe after you do the outer cut, you should construct a tapered extrusion from the resulting edge and then use that to cut the inner tube with.
That looks like this:
Cut outer ring with angled box:
Do not cut inner ring with another box, instead generate tapered extrusions from the edges:
Make one on each side, use the "Flip" option in tapered extrusion for the other one:
Now it's these tapered extrusion surfaces that are used as cutting objects and also cut by the inner tube as well. When combined after the pieces are trimmed it will look like this (3DM attached also):
Is it right? Is it a uniform angle of the transition surface the thing you're trying to achieve?
