Modelling a Böbbel
10096.5 In reply to 10096.4
Load your File
Select All the ring then Separate! ;)
Cick on the empty Space for Deselect
Select the 4 curvated Surfaces(by clicking one by one) wanted to deform
At the end of this 4 selection "Show Points"
You must have all ring "Show Pointed" + 4 Surfaces "Pointed" enlighted
Press Tab & Write SchrinkTrimmedSrf
You must have only 4 surfaces Pointed!
If you have not enough Points just Add Points as you want (always on these 4 surfaces)
Have fun modeling!
PS
If you want all ring as "Show pointed" don't make the 4 Surfaces Selection and the SchrinkTrimmedSrf
then click a big Surface then move points etc...the 4 Surfaces must be separated again for moving points shown!
EDITED: 3 Jan 2021 by PILOU
