Modelling a Böbbel
10096.43 In reply to 10096.39
Hi Lara,
> I tried an other way...but the result was exactly the same. I made a offset of the two big circles
> and moved it for 1 degree together. Sweep along the segment.
I'm sorry but I still don't understand what the problem is.
So you've got this:
Looking at these edges by themselves:
In the Top view, the distance here on-screen:
Will be different than the distance here on-screen:
So yes that is true but it's just how projection of a rotated shape works.
If you have a regular truncated cone like this:
If you rotate it:
Then view the rotated cone in a top view projection it will look like this:
That's normal and it's just how geometry works with projection.
If you wanted the projection to look like this:
That would need a slanted cone rather than a regular cone:
