Something similar to this, making separate outer and inner pieces.
First an outside piece which will be cut by these planes:
And then discard these areas:
And then a smaller inner piece which will be cut by these planes:
And have these areas discarded:
So now the outside and inside remaining pieces look like this:
You can select these spots and do a Loft to connect them, then Edit > Join the pieces together:
Hope this helps!
    -  Michael
