Hi Mala,
> > "If you click on CTRL during the drawing you will have "Sharp" junctions between Control Points..."
> Noticed no different in sharpness-.
Here's an example - this is using the Draw curve > Freeform > Control Points command, and on the 3rd point I'm holding down the Ctrl key and you can see that it leaves a "corner point" that is sharp rather than making a smooth curve at that spot:
