Ui scaling porblem?
10095.2 In reply to 10095.1
Hi Chris, that looks like the kind of thing that can happen if you have installed a customized moi.css file made from moi v3's moi.css file.
If you restore the original v4 moi.css file those should go away most likely.
If you have some customizations to moi.css that you want to have in v4 if you can post your moi.css I can probably tune it up to have the new flex-box properties that the V4 UI is set up to use. V3 used an older and now deprecated webkit specific flex-box for layout. The V4 UI is structured to use the newer standard flex-box properties and if you yank those away and only have the old webkit flex-box properties set up in moi.css you will have the kind of layout problems you are experiencing.
