Is it possible to select one of the faces of an object and then scale it?
10091.31 In reply to 10091.28
Hi Psygorn,
> Is it possible to make a command or button that helps you to achieve what I mentioned? for
> example imagine you select a face of a cube u run that command then it separates the face,
> give you the ability to scale it and then makes it joined to other edges using loft order and
> gives you one single piece?
Well it could be possible but it would only work for special cases as well.
For example this object:
Would generate this result:
So that could be pretty weird.
It's better to construct your scaled object from the start.
