Is it possible to select one of the faces of an object and then scale it?
10091.28 In reply to 10091.26
Yes Dear Michael :-) I understand that things work differently in NURBS modeling.
Is it possible to make a command or button that helps you to achieve what I mentioned? for example imagine you select a face of a cube u run that command then it separates the face, give you the ability to scale it and then makes it joined to other edges using loft order and gives you one single piece?
