Is it possible to select one of the faces of an object and then scale it?
Frenchy Pilou (PILOU)
1 Jan 2021 (20 of 32)
10091.20
In reply to
10091.19
In your case Merge will works with only a face + your closed curve! :)
Boolean Diff with this same Surface + Closed Curve will make a hole like expected in normal use (without Keep objects)...
EDITED: 1 Jan 2021 by PILOU
