Network Hell
10089.2 In reply to 10089.1
Hi Liam, can you please post your .3dm model file with the curves you are trying to network?
From the screenshot my best guess is that you might not have a compatible curve grid setup. Part of how Network surface works is it has to be able to unwrap the curves into a 2D grid with one set of curves being the horizontal grid lines and the other set being vertical grid lines. Kind of like how lines of latitude and longitude on a globe correspond to horizontal and vertical lines on a 2D map of the globe.
So similar to a globe if you have a "north pole" type location, you shouldn't have a curve that crosses over the pole over to the other side of it, you need to cut curves into pieces so they have an end point at the north pole not going past the pole.
Also there are some tips here for people coming from a poly modeling background, they may be helpful:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
