V4 released!
10083.139 In reply to 10083.137
Hi Marco,
> Select all objects (solids or surfaces) that belongs to the currently selected edges (and, at
> the same time, deselect the input selected edges)
You can get the selected edges using this:
var edges = moi.geometryDatabase.getSelectedObjects().getEdges();
Then you'll want to loop through every edge something like this:
for ( var i = 0; i < edges.length; ++i )
var edge = edges.item(i);
To deselect the edge you would do:
edge.selected = false;
To get the parent surface or solid of the edge you would do:
edge.getParentBRep();
So putting that all together it would go something like this:
   edge.getParentBRep().selected = true;
Hope that helps! - Michael
