Q: Assign Series of Object Snaps into Hotkeys.
10081.2 In reply to 10081.1
Hi Elang, yes this is possible by putting in some script as the "Command" part of the shortcut key under Options > Shortcuts.
These are controlled by the moi.drawingAids object, which has these properties on it that can be set to true (checked) or false:
objectSnapOrigin
objectSnapAxis
objectSnapEnd
objectSnapMid
objectSnapCen
objectSnapInt
objectSnapQuad
objectSnapPt
objectSnapOn
objectSnapOnSrf
objectSnapPerp
objectSnapTan
objectSnapPerpPerp
objectSnapTanTan
> - Ctrl + Alt + 1 : Checks (enable) Object Snap for Origin, Axis, and Points, and DISABLE any others.
This one would go like this:
script: var da = moi.drawingAids; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapPt = true; da.objectSnapEnd = da.objectSnapMid = da.objectSnapCen = da.objectSnapInt = da.objectSnapQuad = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = false;
> - Ctrl + Alt + 2 : Checks (enable) Object Snap for End, Mid, Intersection, and DISABLE any others.
script: var da = moi.drawingAids; da.objectSnapEnd = da.objectSnapMid = da.objectSnapInt = true; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapCen = da.objectSnapQuad = da.objectSnapPt = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = false;
> - Ctrl + Alt + 3 : Checks (enable) All of Object Snap.
script: var da = moi.drawingAids; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapEnd = da.objectSnapMid = da.objectSnapCen = da.objectSnapInt = da.objectSnapQuad = da.objectSnapPt = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = true;
For MoI v5 I've made a note to add something to set all or clear all with one script function call to make this kind of script to be shorter.
Hope this helps! - Michael
