Hi Phr0stByte, well I wasn't sure if you mean you had already tried running it under WINE and you saw that everything worked except the display, or if you were just guessing that the display would be the only problem.
I think that there are several other parts of MoI that probably also won't work under WINE, not just the display.
But if I remember right, there is an option in WINE to use actual Windows DLLs when it runs - that might have a greater possibility of working.
