after the purchase i've started to customize my experience already and loaded in the custom UI with the additional needed scripts(I simply cant without UI changes/scripts coming from blender ;) ). And I found your split sidepanel startup script which I also installed...the only problem here is that the transform window will always come up closed after every restart of Moi even when they both open before.
I want it like that on every start if possible :
And the second thing is that when I set my unit size to e.g. mm in options, the next time I boot Moi up it will be set to "No unit system". Is this intentional?
Version: dec 21 v4 beta
Thx :)
