2D pdf Export problem
10072.1
Good evening to all. Merry Christmas to all.
1) I would like to submit this issue that I have been working on now to Michael.
I'm trying to get a .pdf export (for laser engraving) out of this file with keeping mm units, I can't (it's always truncated). I've tried all the options: centering on the sheet, using a custom paper size. Nothing works. .I tried with a .dxf output, I lost the curves under Sketchup and several elements. I could not recover the .ai under the last version of Gimp2, it did not recognize it. I'm working with the beta version V4, maybe I should use v3 but I thought the export tool was the same... I still have a lot of fun working with MOI but I have to admit that I'm stuck now ...
2) Concerning .pdf export, i have notice dimensions lines are not exported. Is it ok ?
Thank you for your help, Pierre.
EDITED: 20 Dec 2020 by PIERREARCHI
