Metal stand problem
10067.4 In reply to 10067.3
Hi Tony,
1. Establish some desired dimensions.
2. Use Rectangle to make an end 2D profile. e.g. width 6" by 2". (red & green lines)
3. Offset to the inside to give the U form thickness. e.g 0.25".
4. Remove the top of the rectangle to make a U. Trim with lines or extend two interior side lines and trim, close top 0.25 gap. (Red end surface)
5. extrude to 12'' (Only about 6 to 10 inches will remain in the finished bracket.)
6. Boolean Difference the 2" sides at an angle, say with a sloped line. The U is now a solid
7. Use Rectangle and extrude again to make the center rise. 0.75" tall, 3.5" wide, and 8" long. A solid.
8. Place solid in the center of the U, about 1" from the end profile of the U.
9 Fillet the solid center, top edge and bottom edge...Remove excess bottom side...
10. Make the "trailer ball mount" It could be a sphere, offset, with bottom 5/8 cut off. Or just revolve an arc, or an offset arc, or ...
11. The "neck" could be made in various ways...
I'm sure others will help...
(model not to scale...)
EDITED: 17 Dec 2020 by BEMFARMER
