Hi Tony,
Just a few started suggestions:
Make a few basic shapes, and remove unwanted portions. Also use fillet, maybe blend.
The ball shape can begin as a revolved (quarter) circle. Maybe use blend also.
Extrude 3/4 of a 2D rectangle (with added thickness) to make the "U-Channel", to your desired dimensions, with extended length.
The rise in the middle, an extruded rectangle, maybe tapered. Then add fillet's. Remove bottom.
The neck?
