Metal stand problem
10067.19 In reply to 10067.16
Hi Tony, so the problem is that with the projections happening from 2 different directions it will still yield a sharp area like this:
To avoid that sharp edge there it could be good to form a smooth path by putting in a blend curve, and then since the blend curve is not directly on the surface you would need to form a parting surface by something like a sweep:
