Sweep stays editable...or not
10053.7 In reply to 10053.1
Hi Mala, the edit mechanism behind that is called "History" or "Construction history", that's just what Brian was mentioning above.
> But I cant do this for new rings?
> Why? I need creating the editable sweep...
You should be able to do it to new rings too, if you have an example where it is not updating can you please post the .3dm model file for it so I can take a look?
One thing that I should mention though is that if you have done some more operations on the sweep like used a boolean on it, then currently that is normal that you will lose the history update in that case.
But if it is just only the sweep without anything else done to it that should be editable through history updates.
