Equidistant array on surface / automatic Pave
10052.13 In reply to 10052.12
Here is a copy of the node program I did in ~2019.
The Macro goes in the nodeeditor macro directory.
The Demo goes in whatever node programs folder that the user wants.
So many old versions and incomplete versions, and a few missing node mods, and hard drive failure, makes it hard to sort out the good nodes.
James' macro was hexTesselation.nod, per memory.
The hex centerpoints could be flowed onto the frogback surface.
One gem could then be copied to each new point on the frogback, but the gem would need a normal,
and each mapped point on the frogback would need a surface normal, to sit normal or tangent to the surface.
Also, I do not recall any batch copy of an object to multiple points.
Maybe a script could be written...
Starting to get into Mesh programming, rather than Nurbs.
The Rhino Pave video looks nice. Must have been a very involved programming effort...physics...
As I recall, forum references to circle packing likely not be of much benefit, so no more looking.
Came across a lot of conformal mapping papers, mostly inscrutable, but grist for new scripts...
