I've been experimenting with the Inset function lately and I have found a couple of issues with it. I'm a new user of MoI so I might not be using it the right way, or maybe there are bugs that I am unaware of and most of you already know how to deal with.
So far, what I have found is that the Inset function seems to be working fine when used on newly create solids, and on 90 degree angles surfaces.
Here you can see my first test. The Inset function is working well for a newly created Cube solid. It also works well with the same cube rotated slightly. If I take the same cube and create a Chamfer, this is where things start to fall apart. I can't create an Inset on the highlighted face, I get a computation error.
Here, I've extruded the front face of the cube with the Chamfer and then tried to Inset some of the faces. The explanations are annotated in the image itself. The face next to the face that was getting an error, is working properly and is the only one giving me the expected result: an inset aligned with the selected face, 90 degree. All the other ones are not resulting in this expected result, some sides are 90 degrees, and others seems to be aligned to the adjacent faces.
This shows in details the errors / unexpected results of the Inset function.
I would really appreciate if someone could explain me what I am doing wrong, or if I have hit the limitations of this function.
Thank you.
